Sponsored by: CARiD
2-2 drop question HELP
Old May 11, 2013 | 09:11 PM
Youngone2012's Avatar
Im currently on a 3/4 drop on 4" leaf springs and belltech struts up front and a carrier bearing kit as well... will the carrier bearing kit be ok if I lift up the rear 2" with a 2" lift shackle and raise the strut up to almost stock height??? thanks
Old May 11, 2013 | 11:51 PM
I'd say go back up 1" all the way around and you should be fine, 2" is going to jack the drive line up all over again
Old May 12, 2013 | 06:20 AM
I forgot to mention this was my 2012 fx2 screw, if that matters... Darn i was hoping I could keep that carrier kit on there with it up 2 inches in the back and the front up 2". When it was stock and I had rear drop shackles it had vibes already, but I don't know if the solution for that was the carrier bearing kit
