Sponsored by: CARiD
2" level causing bulldog rake?
Old Mar 26, 2013 | 10:35 PM
I recently put a 2" AS level on my 2006 2wd Screw, and my front end is about a quarter inch higher than my rear. There are no blocks or AALs on my rear suspension and the truck has 85k on it. Could my leaf springs be sagging/worn/warped? I took a look at em and I would describe their overall shape as closer to a wave than the usual "banana." Any insight would be greatly appreciated!
Will try to get a picture if I can get my phone at a good enough angle
Old Mar 27, 2013 | 12:45 AM
Buxton91's Avatar
You put a leveling kit on. Some trucks sit a tad higher up front after installing one.
Old Mar 27, 2013 | 03:31 PM
I know, but my model isn't supposed to do that with a 2 incher. That's why I feel that that isn't normal. A 2.5 should do that though. I guess just get an AAL now!
Old Mar 27, 2013 | 04:11 PM
pizzaman711's Avatar
06-08 generally only needs 2" to level, 2.5" would be for 04-05 for your body style. But since no truck is exactly the same and leafs do sag over time it's just a general rule.
And why an aal? Are you trying to get the stock rake back?
Old Mar 27, 2013 | 07:29 PM
Well I just figured that if my leafs are sagging I'd might as well help them out instead of just putting a small block under them. I think I'd be alright with a 1.5" rake, make it look like stock a 4wd haha
Old Mar 29, 2013 | 03:25 PM
Buxton91's Avatar
Did they look to be sagging before the level?
Old Mar 30, 2013 | 11:13 PM
Not sure, that's what I'm wondering about. I don't know how to tell if they are sagging or not cause all the springs I've looked at seem similarly shaped. But they must be sagging if a 2" level did that. I have no idea what kind of towing the truck experienced for its first 74k miles, assuming a good amount haha
