Sponsored by: CARiD
Sway bar endlink question..... 07 fx2
Old Mar 19, 2013 | 07:48 AM
ldmonty's Avatar
Ive been searching many different sites on this topic. I have a clunk in the front end of my 2007 FX2. I found the issue to be the endlink on the passanger side, the "ball joint" style lower end of it is poping in and out.
Does anyone know if a company makes the original, straight through style of endlinks like in the 97-03 f150s, for my truck? If not, does anyone know of an established brand that will work?
Dad and I spent the entire weekend upgrading the suspension with Belltech 2/3 drop system and rear sway bar. While at it we also changed out the Upper A arms (Moog), Lower ball joints (Moog), Outer tie rod ends (Moog) and Sway bar endlinks (Raybestos, should have kept the consistancy). Just had the final alignment yesterday and now I want to fix the last thing so I can eliminate the suspension as an issue to worry about.
Thanks,
Old Mar 19, 2013 | 08:29 AM
I changed the bushings and end links to Moog. Seem to be doing well
Old Mar 19, 2013 | 10:33 AM
sam1947's Avatar
I am on my third set of MOOG links in 45,000 miles and they are getting noisy. They have been greased every 3 to 4K and still wear out. I don't think MOOG has the quality that they used to have, got no idea what to use next.
Old Mar 20, 2013 | 07:24 AM
ldmonty's Avatar
im tempted to purchase a universal endlink and see how it fares. I would like to avoid the ball joint style at the bottom.
http://www.energysuspensionparts.com...-End-Links.asp
something along those lines. ^ ^ ^
