leveling kit for my 11 FX4
2-inch Daystar on my 2011 XLT:
2-inch Zone on my 2013 FX4:
Both are good systems but the Zone has the better polyphthalamide material which is tougher than the polyurethane systems like Daystar since polyphthalamide is more resistant to heat and has more compressive strength. But I have run the Daystar leveling system on a number of my trucks and never had any issues.
I did AS 2" on the front of my 2013 FX4 but the longer I looked at it the more dissatisfied I became. Sometimes when parked it looked nose high and when driving it appeared that way too. So to remedy that I replaced the rear 1.25" blocks with 2" blocks and it sits perfect now, up with a slight rake so no bed loads make it sit down.
I have the Rough Country leveling kit on my 10 FX4.....I also purchased the performance 2.2 shocks.....rides very good....
So I just Installed the 2" Level Kit on mine, Same as last post looks like the front is up just a bit more then the rear, Are most of you adding the Block in the back and will that help with sag when towing a trailer, Or are airbags a better idea,
Airbags would be best but also more expensive
air lift from auto anything is 258 firestone is 360 ish..both could be installed in ur driveway with hand tools..i plan on doing this down the road some time.
http://www.autoanything.com/suspensi...A2966A0A0.aspx <- just air lift search for firestone.
