Sponsored by: CARiD
need help!!!
Old Jan 14, 2013 | 05:10 AM
cowboysdeath's Avatar
need help!!!
hi im new to the board! and i just got my first truck its a 2000 f150 7700 2wd 8 foot bed im looking to do a few mods to it its got ifs in the front and i wana put a 3in leveling kit on it but i cant find 1 anywere its got the 7 lug pattern. also the fuel pump aint kickin on i droped the tank yesterday but u cant rember which prong for the fuel sending unit gos to the pump i got a test meter but i dont wana frie it i need the help yall thanks!!!
Old Jan 15, 2013 | 11:05 AM
wandell's Avatar
If you have a 4x4, stay far, far away from "leveling kits". All they are is reindexed torsion bar adjustment keys. THey allow you to put way too much preload on the torsion bars which will destroy your ride quality and leave your CV and ball joints at such a severe angle they won't last. Just crank up the preload with your stock keys enough to level the truck. If you want a little more lift, you can add a 3 inch body lift.
If you have a 4x2, you can add 2 inch Daystar coilspring spacers inexpensively. 2 inches is as high as you can go on the 4x2's with spacers or lift springs without needing longer upper control arms.
Old Jan 31, 2013 | 03:34 AM
Will the 1.5 inch leveling kit from them fit the 7700 tho I have 7 lug wheeles will that make an issue on the fitment and do u know if that will ware out ball joints and other parts in the front end faster
Old Jan 31, 2013 | 12:34 PM
wandell's Avatar
Yes, the 1.5 inch spacers/leveling kit will work. Your wheels have no affect on what leveling kit you use. Anytime you lift the front end, the ball joint angles will increase which in turn increases the rate of wear. How much is a matter of debate. But most people agree that 2 inches or less does not increase wear and tear significantly.
