Sponsored by: CARiD
Leveling kit + Belstein leveling shocks?
Old Dec 12, 2012 | 11:00 AM
ninjaguy's Avatar
Whats up guys?
I am searching for this and can't seem to find an answer anywhere. I have a 2wd truck and was going to lift it but decided that I can't afford it being a college student. I have a leveling kit on my truck currently and am running 33's, could I put the Bilstein 5100's on my truck also for a little more height and put a 3" block in the rear? I am trying to fit 35's on my truck. Just wondering if this would work or if it is going to just mess up everything on my truck.
Btw, I don't need to responce of, 2wd should be lowered, get that enough from my buddies. Lol
Old Dec 12, 2012 | 11:08 AM
pizzaman711's Avatar
Your not fitting 35's without an actual 6" lift.
Old Dec 12, 2012 | 12:43 PM
wandell's Avatar
No, you cannot combine a leveling spacer and adjustable Bilstien shocks. The ball joint angles would be too extreme to last, even if you could get the front end bolted back together. Your options are basically this: add a 3 inch body lift or save for a full 6 inch suspension lift.
Old Dec 14, 2012 | 12:07 PM
ninjaguy's Avatar
Dang, ok. Figured I would check before I spend the money on them.
