Sponsored by: CARiD
hell bent steel level
Old Nov 1, 2012 | 09:23 AM
millerman's Avatar
Just got my hell bent steel 2.5" front end level kit. Ive noticed a lot of guys also doing something with the rear as well. If i don't block the rear is my front end going to look crazy higher or will it just look "level" unloaded?
Old Nov 2, 2012 | 05:15 AM
06F150CFCT's Avatar
If you have an 05 like it says in your info, you should be fine with the 2.5". It may sit a tad nose high but no more than .5". I had this on my 06 and it sat half an inch higher up front. The guide is that a 2.5" will level out a 04-05 and a 2" will level out an 06-08.
Old Nov 6, 2012 | 06:18 PM
ryan42680's Avatar
I have the HBS 2.5" on my 08 4x4 scab and it sits perfectly level unloaded. I am installing the ProComp long AAL this weekend though, lots of winter driving with an 08 Ski Doo in the bed and I hate the sag.
Old Dec 6, 2012 | 09:50 AM
07fx4supercab's Avatar
I too have a HBS 2.5" kit on my '07 FX4 and I didn't like the way it sat. The front was a little high for me so I put a 1" block on the rear. I like the truck to sit a little lower in the front. Plus it adds another inch!!!
My humble opinion.....
Old Dec 8, 2012 | 07:25 AM
millerman's Avatar
I guess my next question is, then if i 1" block the rear and 2.5" level the front are my tires going to look funny?
Old Dec 8, 2012 | 12:14 PM
97isnotold's Avatar
I guess it all depends on what kind of personality your tires have and what kind of jokes they tell.
#youseewhatididthere
FishingJunkie92's Avatar
I would not do a block. I would get a 1.5 inch Pro Comp Add Leaf
Old Dec 8, 2012 | 01:07 PM
97isnotold's Avatar
2.5" will level the truck out perfectly. 1" block will give you rake.
i don't know if you are 4x4 or not but heres my fx4 with a 2.5" HBS on 35's
Old Dec 16, 2012 | 03:13 PM
scheer89's Avatar
I agree with fishing junkie. I added blocks and it put so much pressure on the middle of the leaf that it made them almost flat loosing some use of that suspension. I just added a 2.5in add a leaf and the stock block and removed the 3 in block and I increased the height by 1.5 in. Mine has some rake to it but that's because I'm usually towing
