Sponsored by: CARiD
Do i need an alignment with coil spacers
Old Jun 13, 2012 | 12:43 AM
jkelly941's Avatar
tomorrow im putting in 2 inch coil spacers on my truck and i was wondering if im gonna need to get an alignment after its done? my truck is a 06 f150 xl 2wd. Also will i need to get an alignment after installing new tires and wheels? Thanks for the help
Old Jun 13, 2012 | 06:05 AM
whitt91's Avatar
yes if you change the suspension. not positive on the tire and wheels though i dont think so.
Old Jun 13, 2012 | 09:23 AM
pizzaman711's Avatar
Yes after leveling kit, no after tires. As for coil spacers, I assume you mean one of the leveling kits that bolts above the coilover.
Old Jun 16, 2012 | 10:49 AM
06F150CFCT's Avatar
Agreed...if the tire place does a good job mounting and balancing them you should be all set with that but definitely need an alignment after the level. Depending on how long you wait in between installing either you could just do it after both things are installed.
