Sponsored by: CARiD
What is the going rate for a front end allignment?
Old Jun 6, 2012 | 01:17 PM
Hunt&Fish's Avatar
My local 4-wheel parts shop said an alignment for a truck with a suspension lift runs 140.00. He also said they do a great job, and I will be pleased.
Sound about right? I don't mind paying more if I don't get crappy work.
Old Jun 6, 2012 | 01:31 PM
wandell's Avatar
It ranges greatly from area to area. A two wheel alignment in my area is $40. I've read on here about people paying $75-$100, but $140 sounds really high.
Old Jun 6, 2012 | 02:03 PM
1997 lariat 4.6's Avatar
i have a place that says you need ball joints every time, needless to say we don't go there often after we replaced ball joints and took it in to be aligned and they claimed it needed ball joints... it was about 150 there, and down the road was a place that knew what they were doing and its about 50 bones.
Old Jun 6, 2012 | 02:35 PM
beechkid's Avatar
25 Year Member
IMHO, that would be the upper range. Typicaly 4-wheel front end alignment is on avg $80.
Old Jun 6, 2012 | 03:17 PM
kingfish51's Avatar
If any one states that your F150 needs a 4 wheel alignment or they can do one on an F150, walk away. There is no such thing on an F150. Only the front can be aligned. Cost for a front alignment at my dealer is only about $50 to $60, assuming no parts are needed.
Old Jun 6, 2012 | 06:54 PM
beechkid's Avatar
25 Year Member
What I think he is referrering to (I'm hoping anyway), is where they are not just doing a conventional front end alignment (which is perfectly fine) but aligning the fronts off of the backs....so to speak.
Old Jun 10, 2012 | 06:02 PM
ace1602's Avatar
I just had a lift kit put on and the charge to align the front end was 100
Old Jun 11, 2012 | 03:32 AM
06F150CFCT's Avatar
Luckily I have a buddy that works for a shop so I got my alignment for $40when it would normally is $120 for a lifted truck.
Also, there are cases where you need to align the back of our trucks. Mine is out 0.04 degrees. When you put the lift in, if you dont center the axle, your rear end will be out of alignment and "crabwalk" down the road. Kind of like you see some older trucks with the rear end wayyyy outside of the front tire path, almost going sideways down the road. So in essence you cant align each wheel but you can have the rear of the truck out of alignment with the front.
To fix the rear, they just have to loosen the U-bolts and slide the axle from side to side to get the right alignment. The shop I went to said they didnt have a lift high enough to do mine. They dont see very many lifted trucks.
Old Jun 11, 2012 | 07:12 AM
Hunt&Fish's Avatar
Thanks for the replies.
Old Jun 11, 2012 | 07:51 AM
TRUCKSTUFF's Avatar
Front alignment around my area is about $50 buy it can range from $50- $100. I havent heard it being more than $100 at least not where I am from.
Old Jun 12, 2012 | 12:51 PM
MossyOak3006's Avatar
I pay $70 for 4 wheel alignment. I have a 6" lift and 35s
