Sponsored by: CARiD
aal or bigger
Old Apr 8, 2012 | 10:15 PM
damiansalmond's Avatar
aal or bigger
Anyone on here swap out the leaf springs on the 2004-2008 truck for F250 leafs? I need stiffer leaf springs and I am caught between getting an aal kit or just having bigger leaf springs installed. Any suggestions?
Old Apr 8, 2012 | 10:17 PM
MossyOak3006's Avatar
Are F-250 leafs the same length as F-150 leafs?
Old Apr 9, 2012 | 01:11 AM
Not sure, I was curious on if anyone has tried it yet
Old Apr 9, 2012 | 08:23 AM
pizzaman711's Avatar
I think they're longer.
Old Apr 9, 2012 | 08:37 AM
06yz250f's Avatar
^^this.
and the rear end will ride more stiff than an f150 w/ an AAL.
Old Apr 9, 2012 | 05:11 PM
igofshn's Avatar
Put air bags on instead. You can adjust to what you are doing.
Old Apr 9, 2012 | 09:25 PM
I need something that will stiffen the rear end up and make it sag less with wieght on it, I think an aal will do that, but how well will it work?working
Old Apr 10, 2012 | 12:39 PM
jaws12's Avatar
Are going to be hauling heavy weight frequently?
Old Apr 10, 2012 | 05:55 PM
06yz250f's Avatar
Airbags you can set it to have zero squat in any situation. IMO it's the best route if you don't mind higher price tag
When ever i level out my truck thats the route i will be going so i don't squat. I did an AAL on my last truck and while it was nice, it was jarring over a few situations
Old Apr 10, 2012 | 11:31 PM
mdhawkin's Avatar
I agree on the air bags. Just curious how much weight are you talking about?
Old Apr 15, 2012 | 11:17 PM
I reagularily have 1000 to 2500 pounds of wieght back there. I just don't like the way the truck squats with all that wieght. It almost rides on the bump stops with anything more than 1500 pounds back there. I have never done air bags or an aal, so, ease of installation is a factor also.
Old Apr 15, 2012 | 11:49 PM
06yz250f's Avatar
both installs are simple. If you have a wide range of weight in the bed, go air bags as they will adjust to any weight. An AAL will not.
Old Apr 17, 2012 | 05:21 AM
06F150CFCT's Avatar
What about Atlas or Deaver or even these:
http://www.stengelbros.net/43-1555HD_p_596.html
Just throwing out alternative springs for ya.
Old Apr 17, 2012 | 07:50 AM
06yz250f's Avatar
nothing wrong w/ a completely new spring but your ride will most likely drastically change. Also new leaf springs are MUCH more expensive than an AAL and probably more than bags.
The reason air bags are nice is you can adjust the rear height of the truck and when unloaded it's a stock ride.
