Squanto..and anyone else who wants to look
Just want to say thank you. A while back you gave me some info on your Kodiak steps. I installed mine this past weekend. You can see some pics of them at http://www.geocities.com/y2kboti/modifications.html
I have been asked that question a hundred times Paco...and no its not jealously
(thats usually what people think it is) The reason I post on this forum is because of my knowledge w/ IFS lifts.
Squanto I love the steps. Alot easier for my g/f to get in now. Don't have to grab her by the @ss
As for the install it was a B1TCH! Took almost 8 hours by the time everything was said and done. I know thats alot of time but let me explain.
First off I had to buy extra hardware because they did not supply enough. Second the directions that were included made absolutely no sense so I tossed them. Third because of all the fuel and brake lines on the driverside I had to modify and trim some of the brackets. And last, the passanger side step wiring was messed up at the factory. When I opened the door the step went up
So I had to open the motor cover and play around w/ the wiring.
So now that I've said that you have a better idea of what I had to go thru. But still better than spending $250-325 to have them installed.
(thats usually what people think it is) The reason I post on this forum is because of my knowledge w/ IFS lifts. Squanto I love the steps. Alot easier for my g/f to get in now. Don't have to grab her by the @ss
As for the install it was a B1TCH! Took almost 8 hours by the time everything was said and done. I know thats alot of time but let me explain. First off I had to buy extra hardware because they did not supply enough. Second the directions that were included made absolutely no sense so I tossed them. Third because of all the fuel and brake lines on the driverside I had to modify and trim some of the brackets. And last, the passanger side step wiring was messed up at the factory. When I opened the door the step went up
So I had to open the motor cover and play around w/ the wiring. So now that I've said that you have a better idea of what I had to go thru. But still better than spending $250-325 to have them installed.
