Sponsored by: CARiD
Just got 6" BDS Lift, ABS Activating
Old Mar 28, 2012 | 10:24 PM
doollas's Avatar
2002 F150 supercrew, just got 6" BDS lift and 35" tires. Even after correcting for revs/mile with my SCTX3, the ABS will activate at low speeds and acts funny.
Any ideas?
Old Mar 29, 2012 | 06:38 AM
ryanwagner78's Avatar
Did you call BDS and ask about it? Did you do the install? There are several remarks about the ABS system in the instructions, might be worth a check on the install.
Instructions: http://bds-suspension.com/instructions/023600-1-2-3.pdf
From the instructions, for example, :
Route the ABS wire up the front side of the knuckle, through the control arm and up to the inner fender and
reconnect it to the wire connector. Retain the ABS wire to the back of the knuckle with the provided wire clip, ¼” x
¾” bolt, lock washer, and flat washer from bolt pack #535 (Fig 13). Tighten the ¼” bolt to 10 ft-lbs
Old Mar 29, 2012 | 10:45 AM
doollas's Avatar
I had the only BDS "dealer" in New Mexico do the lift. When I noticed I called him right away and he acted like he had never heard of it before, but I didn't do all that good a job of describing the problem. What to do?
Old Mar 29, 2012 | 11:49 AM
pizzaman711's Avatar
Take it back and show them the problem, they installed it so hopefully they'll warranty their work.
Old Mar 29, 2012 | 11:50 AM
jtwoodall's Avatar
Take it back to him and have him fix the problem.
Old Mar 29, 2012 | 12:46 PM
doollas's Avatar
It's like a 1.5-2 hr drive, so if it's something small that I can fix myself, I'd definitely rather do that. It isn't a major issue and I'm taking it to them to tighten everything up after 1000 miles so maybe ill just have him fix it then.
Old Mar 29, 2012 | 03:38 PM
doollas's Avatar
Originally Posted by Crash!
Is the ABS light on? If so, you do have a problem to resolve. This means you are running WITHOUT ABS, because when a failure is detected, the module disables ABS. And you need it, not just in the snow or in the wet, but even dry pavement and in the turns.
The ABS light is NOT on, and I think it is activating:brakes are applied, sensors are detecting fewer revolutions per mph indicating slippage and therefore activating right?
I talked to the programmer of my SCT X3 and they said they can't and don't affect the traction control or ABS. Talked to Ford guy and he said that the abs module does run through the PCM, and so to change it I would have to put the stock tune back on. So that's fine I think I have diagnosed the problem, but now I'm curious if I will be able to put back on my custom tunes after the stock tune is modified. So confused why do these things always happen to me.
Old Mar 29, 2012 | 03:52 PM
1997 lariat 4.6's Avatar
eh crash i agree to disagree... unless it was something added in 99. when my abs light would be on and when i was going under 20mph 95% of the time my ABS would kick on, but not allow me to use my brakes. it would pump backwards essentially. it may just be a wire they forgot to hook up, go all around check all wires and if you see any visible damage to the sensor tips, or wires fix pronto.
Old Mar 30, 2012 | 06:17 PM
doollas's Avatar
Figured it out (I Think)
Ok so I have educated myself on how ABS systems work, and have an idea of what's happening.
When the lift guy was taking off my right front hub, it was all kinds of rusted and stuck so he spent a few hours beating on it, heating it, etc. In this process I'm sure he damaged a ring inside the hub that has to do with the ABS sensor (I have heard of a few different types of rings that go in there, excitor and tone ring and my mechanic mentioned the tone ring). My mechanic kind of confirmed this but it's impossible to say without taking the hub apart.
I unhooked my rear speed sensor to turn the ABS off and all is fine, so now I have to figure out how hard it is to change my own hub and I should be good to go. Any more thoughts?
Old Mar 31, 2012 | 08:09 PM
doollas's Avatar
Lariat-
It is a process of elimination. ABS light on, it is electronic. If not, it is mechanical. I post my experience after years of formal education and training. Beating on things is most likely the problem. One missing tooth will cause a problem.
If the light is NOT on, you eliminated the entire electronic system. There are grease monkeys, mechanics, technicians, and high caliber technicians. A technician would know to grab the manual and do it right, and a hammer is not going to be in the book. I am betting the dealer has a special tool kit for removing the ring if it is servicable.
Electronics are not the problem so it is likely a ring. I don't blame the lift installer for it tbh, everything was pretty rusted and other than penetrating oil, banging, and heat, not much is going to get that stuff off. The dealer would probably charge me out the rear to replace the ring(s) and I can just replace the hubs myself for much cheaper. I'll update this thread when I get everything taken care of.
Old Mar 31, 2012 | 09:10 PM
sbchris's Avatar
First things first, check the abs cable to check for wear, cuts, rips, or if it is being pulled extremely hard. Check from the knuckle all the way up into the fender.
Next I'd check the sensor that slips into knuckle and the abs ring (behind your rotor.) Take the tire off and check it out and compare with the other side. The sensor could be damaged, not fully seated into the knuckle, abs ring dented, abs ring corroded, out of spec and not true, or etc. Who knows you might even have a defective knuckle and the abs pilot hole is not within spec, which would suck.
