Adjusting the setting on Bilstein 5100s
I have a set of Bilstein 5100s on my truck. Currently the setting is sitting at 2". I want a little more level out of the truck.
So I'm planning on adjusting up to a 2.5" leveling kit & setting the Bilsteins back down to 0" setting. When I am taking the struts out while installing the leveling kit does anyone know how to adjust them? I can't find a source online on how the settings work.
Any help would be much appreciated
You have to remove the spring from the shock and reposition the ring that holds the spring perch to the appropriate slot. Once you get the spring off, it's pretty self explanatory when you see it. Move that ring and reassemble.
You'll need a compressor. Or, you can take the struts down to your nearest front end shop, toss them $20.00, and let them compress the spring and move the little clip. I have found that this takes a lot less time than going to your nearest parts shop, borrowing the compressor, compressing the spring(sort of scary), then returning the compressor.
HYPO
HYPO
If you are hell bent on doing it this way, ya may as well change all 4 ball joints now and get a head start on em, you are going to do it sooner than later with the spacer anyway.
If it is a little too high on the back end, have you considered swapping out the rear spacer to something less tall, say a 2 1/2 inch instead of what I assume is a 3 inch?
Well my deal is that it is a pretty raked right now. I wish it was more level. That is the main thing. The 2" level just didn't do it for me.
That's what I've been suggested to do with out doing a body lift or something
Or lower the rear end.
Hmm....alright. I really don't plan on lifting it. I got 100k on this truck and it's a daily driver. I just don't see spending that kind of cash on a truck I don't offroad that often anyways.
On the 2009+, the 4X4 comes with a 1.25 inch block from factory. I believe the 04-08 came with a 1.5, but not positive about that. I am positive about the block I pulled out of my '10 though, it is positively a 1.25". When I put my 5100's in at max height, the truck sat nose high with the factory blocks in the rear, so I replaced them with a 2 inch block, and leveled it almost perfect. If you have the Bilsteins set at max now, and you are positive about this, then you MUST have at some replaced the rear block with a 3+inch block, or done an add-a-leaf, or even air bags add-on, if you still have alot of rake. With the factory blocks, and factory springs, and 5100's set at max, you would not have a rake problem.
What measurement is the current block you have in the truck now? It's a pain in the rear to get a true measurement, especially with the way you have to tilt your head to get a good reading. I think dropping the back end is a much better option.
