Sponsored by: CARiD
SAS leaf help needed.
Old Feb 28, 2012 | 04:48 AM
Rock Krusher's Avatar
Finally gonna bite the bullet and do my sas on my 01 f150. My front Dana 60 is in the process of getting rebuilt then its go time. The problem I'm having is what leaf springs to run in front? I've searched and searched all over fullsizebronco.com but there isn't a lot of info there on the 97+ trucks. I plan on using f350 hangers and shackles. Will stock 96 f350 springs give me enough clearance to clear the stupid crossmember in the front? Or will I need 2 or 4" 350 leaves? I've heard u need 7 to 8" of total lift to clear the crossmember. The truck won't be used for hardcore offroading, just mild. It prolly won't be stuffed hardly ever, if at all. Thoughts?
Old Feb 28, 2012 | 07:44 AM
dilloncawthon's Avatar
if it's just to be used for mild offroading then you're wasting a lot of money on something that ifs can do. the point of a sas is to allow greater flex and stronger axles for larger tires than the ifs can handle. solid front axles are the best no doubt but it just seems like a waste if you're not using it.
Old Feb 28, 2012 | 08:03 AM
pizzaman711's Avatar
Yea why are you doing an sas for just mild offloading?
But pm klitch on here, I'm sure he could give you an answer.
Old Feb 28, 2012 | 08:18 AM
Just making the truck the way it should of been made from the factory.
Old Feb 28, 2012 | 09:22 AM
ha well I agree with that, I guess its better to have it and not need it than to need it and not have it.
Old Feb 28, 2012 | 09:30 AM
That's the exact thought that started whole process. LOL
Old Feb 28, 2012 | 09:50 AM
That makes sense to me, make sure you take a lot of pics as you go along and do like a build thread on here for it. It'd be nice to have a few sas threads to refer people to when they ask about how to go about doing it and what all is involved.
Old Feb 28, 2012 | 12:39 PM
06yz250f's Avatar
running 3/4 ton to 1 ton leaf springs is going to net you a rough ride...
Old Feb 28, 2012 | 04:44 PM
From what I've read its only the 250 springs that ride rougher then a cob. The 350 ones ride fairly decent from what I hear. Of course they are stiffer then factory, but not as bad as a stock f350.
Old Feb 28, 2012 | 08:13 PM
_JR_'s Avatar
When I did mine I used 73-87 half ton chevy springs and built all the hangers from scratch. I believe if you use the f350 springs you will have to lengthen the frame as they are longer. also the half ton springs will ride nicer than the f350s
Old Feb 28, 2012 | 10:15 PM
Jr what year truck do you have? How big of lift springs did you use and how much total lift did you end up with?
Old Feb 29, 2012 | 05:14 PM
_JR_'s Avatar
My truck is a 99. I used 8" lift springs and built another 5-6" in my hangers plus i have a 3" body lift on top of that so I ended up with 16-17" of lift. I was running 44s but I got a set of 40s now so I'm going to lower it 4" and run those. I'll be replacing the 8" springs with 4" ones. I know you dont want that much lift but you could probably get away with using 2" springs depending on how you build your hangers but the minimum amount of lift you could have will probably be around 7-8"
Old Feb 29, 2012 | 05:27 PM
Yeah I'm shooting for about 8" total. I already have a 3" body lift but I may take it out. I don't plan on going bigger then 37s. I think 8" and 37s would look about right .
Old Feb 29, 2012 | 07:22 PM
4.2trimble's Avatar
us 45.5" eye to eye chevy leaf springs they are easy to find and ride decent for what they are.
PM me I still have my whole Farmboy Fabrications SAS kit forsale
Old Feb 29, 2012 | 07:24 PM
4.2trimble's Avatar
