largest tire rim combo
hi, I have a 1998 f150 2wd w/3" body lift and a doetsch 5" lift on the way, its the spindle and coil lift. I was just trying figure largest tire and rim combo to give it a good stance, I will also have pocket flares too. I want fill the area out to the fender flares up as much as I can, with out rubbing. Any suggestions are really appreciated. Right now I run stock 17" rims with 295/70/17 terra grapplers, with little rub at full lock, only body lift is on. Thanks everyone. Could a moderator move this to wheels and tires, I thought that's where I was posting. Thanks.
Since the pockets don't actually give you anymore clearance you still have to watch for rubbing on the inner sheet metal, but a 10" wide wheel with somewhere between 4.25-4.5" backspacing would set you out nicely with a wide stance. Since the spindles will also knock you out another 1.5" per side anyways.
