Kmc wheels, 34s, 2.5 level kit?
I've got an 09 lariat 4x4 I recently bought a level kit from rough country and I want to add 275/65r20 nitto terra grapplers with some 20x9 kmc wheels. The wheels I'm looking at I can get in a -12 offset or +12 offset.
My question Is, has anyone ever done this set up with a similar truck without any problems or mods like trimming splash shield? Does it make a difference with what offset I get?
Thanks for reading
Thanks for reading
Im about to install a 2.5" leveling kit with BMF wheels that have a 0 offset and my 33" Toyo MTs and i know i'll have some minor rubbing.. If you go -12 then you will need more than a leveling kit.. But +12 should be fine
For what it's worth, I suggest that you do not go with a 2.5" leveling kit on an '09. With an AS 2" leveling kit on my '09 4x4, the UCA angle looks like:
I am not too thrilled with this angle, I certainly wouldn't want more. There is also a scar on the spring where the UCA occasionally hits it.
what size tires are you running? the tread looked like the stock pirellis.
appreciate the input.
Thats Autospring....thats a brand that you should buy because they are only like 90 bucks... Stick with as positive as you can to prevent a lot of rubbage. I have -12 offset in kmc wheel..you can see how far theystick out on my 2010 with a 6" lift....the same wheels on a 3"leveling kit on my06'....i like the look of the negative offset best, but you will have to stick with a 33 if thats what you like
When my ball joints wear out, I will likely replace the AS leveling kit with a set of Bilstein 5100s set to 1.5"
