Sponsored by: CARiD
2"-3" front leveling... kit?
Old Dec 18, 2011 | 10:10 PM
hunter3014's Avatar
i have heavy duty springs in the rear and the font sits way lower than back so i want to get some coil springs on the front to level it out and help fit my big tires.
my question is.. if i add like 2" coil spacer (3" if possible :P), will i need the stud extenders? the extended bump stoppers, or new longer shocks...?
Old Dec 18, 2011 | 10:24 PM
pizzaman711's Avatar
The most you can go is 2" without aftermarket control arms. Longer shocks would be good to help from overextending them or bottoming them out. Read the link in my sig, it should help explain everything more.
Old Dec 18, 2011 | 10:39 PM
hunter3014's Avatar
hmmm okay. well i should be able to get away with it then ya? cause i mean my ride is already stiff so i for real aint to worried about shocks i just wanna level it for real.
wouldnt i atleast need the 3/4" stud extenders?
Old Dec 18, 2011 | 11:28 PM
06yz250f's Avatar
are you referring to your f250?
2wd or 4wd?
Old Dec 18, 2011 | 11:41 PM
Buxton91's Avatar
What "stud extenders" are you refering to? The biggest spacer you can run without aftermarket control arms is 2".
Old Dec 19, 2011 | 12:21 AM
hunter3014's Avatar
yes, my 1999 f250 v10 2wd. and the stud extenders like the ones in this picture. Just about all coil spacers i look at, the include these with it.http://www.ebay.com/itm/BLACK-ALUMIN...ht_2039wt_1344
and are ebay ones any count btw? cause i mean what much difference could they be from some $125 ones other than material their made of.. which does or doesnt make alot of difference ?
Old Dec 19, 2011 | 12:31 AM
Buxton91's Avatar
Oh those are shock extenders. The screw onto the stud on top of the shock. Those ebay spacers don't look to have a groove for the spring to rest in. Seems a little sketchy to me.
One like this would be much better. http://www.ebay.com/itm/Daystar-Leve...item3cbfcd2842
Old Dec 19, 2011 | 12:37 AM
hunter3014's Avatar
yeah i think they go under with the skinny part inside the coil to where when ou bolt it all back together they wont slip or move around lol.
Sooo does that mean i would need them or no? cause i could see where i would to where i wouldnt "max" out my shocks.. know what i mean?
Old Dec 19, 2011 | 01:43 AM
Buxton91's Avatar
Forget all previous posts, seeing as you have an actual SD F250. I thought you meant you have a 7700 f150.
Old Dec 19, 2011 | 08:19 AM
hunter3014's Avatar
oh haha okay. so they'd work fine yea?
Old Dec 19, 2011 | 12:22 PM
Buxton91's Avatar
Honestly, I have no clue. Maybe try asking in the F-250/Super Duty section.
