defective coil springs???
I bought a set of Rough Country coil springs for my 86 f150, they are a set of their 1.5" level springs. When I installed them last nite I noticed that 2 of the coils touch each other
I previously had a 1/2" spacer on the stock springs to try and level out my truck but it just wasent enough with that spacer....so my set-up right now is that level springs with a 1/2'' spacer, is that spacer maybe causing those 2 coils two rub against against each other????
THANKS YALL
I previously had a 1/2" spacer on the stock springs to try and level out my truck but it just wasent enough with that spacer....so my set-up right now is that level springs with a 1/2'' spacer, is that spacer maybe causing those 2 coils two rub against against each other????THANKS YALL
