Sponsored by: CARiD
fabtech lift
Old Nov 15, 2011 | 05:49 PM
thatguy35's Avatar
fabtech lift
i need help figuring out what size lift i have. i think its a 4 but some of my buddies said it looks like a six. i wanna get it higher as well but dont know the best way i should go. any suggestions?
Old Nov 15, 2011 | 10:08 PM
MossyOak3006's Avatar
Fabtech only makes a 6" lift for the 2004-2008 F150. I have a Fabtech 6" on my 2006. Do you have 6" spacers on top of your factory front struts or do you have aftermarket struts?
Old Nov 16, 2011 | 06:47 PM
thatguy35's Avatar
i dont have a clue. i bought the truck as it is. i havent paid any attention to that
Old Nov 16, 2011 | 07:21 PM
If you have the truck with you now you can just take a look. If you have aftermarket struts, you can put a 2" spacer on top of them for more lift. If you have a 6" spacer on top of your stock struts then you will have to buy taller struts to get any more lift than what you have now. So hope you have aftermarket struts already, or you will be spending some big money to get more lift. This picture is my truck with a 6" Fabtech lift. I got Fabtech's Dirt Logic struts
Old Nov 16, 2011 | 08:50 PM
thatguy35's Avatar
appreciate. i dont have the dirt logic struts so i may have the stock struts. i thought about just doing a leveling kit to pick the front end up
Old Nov 17, 2011 | 01:11 AM
Buxton91's Avatar
If you have a 6" spacer on top of your factory struts, then you won't be able to put on a leveling kit. You can't stack spacers, It doesn't turn out good.
Old Nov 17, 2011 | 10:21 AM
That's what I meant by hope you have aftermarket struts. The only way to get higher than what you are is to buy new taller struts. Or you may be able to put a Rancho quick lift under your 6" spacer. I'm not sure about that though. Maybe somebody else knows
Old Nov 18, 2011 | 03:22 AM
mhockey9090's Avatar
yeah dont stake spacers. You need coilovers to replace that big spacer you got in there already to be able to raise it up another 2inches.
Old Nov 23, 2011 | 11:26 AM
thatguy35's Avatar
ive got struts but i dont have the dirt logic struts. by looking at it i think i can put the spacer on top of the struts
Old Nov 23, 2011 | 11:09 PM
Buxton91's Avatar
Post up a picture of it for us, then we can tell you from there.
Old Nov 24, 2011 | 08:57 AM
06yz250f's Avatar
you have coilovers, fabtech also has struts which are similar to what comes factory just longer to accommodate a 6" lift.
Old Nov 24, 2011 | 01:56 PM
thatguy35's Avatar
how do u upload a picture i cant get it to work
Old Nov 24, 2011 | 02:08 PM
thatguy35's Avatar
http://i1133.photobucket.com/albums/...DSCN1209-1.jpg
Old Nov 24, 2011 | 02:37 PM
wandell's Avatar
Well, you obviously don't have Fabtech's optional Dirt Logic coilovers. But that doesn't look like the standard white bodied Fabtech coilovers either. You see, when Fabtech first introduced their lift for the 2004-08 trucks, they came with a replacement white coilover shock. They later redesigned their kit and it came with a 6 inch spacer to be used with your OEM coilover shocks. The Dirt Logic coilover shocks have always been optional. Can you post a pic of the front of your lift?
Old Nov 24, 2011 | 04:40 PM
My bad. I always just use the terms interchangeably. I know it's technically not correct
