Sponsored by: CARiD
Rear leaf spring question
Old Oct 27, 2011 | 01:16 PM
Trhlz1222's Avatar
I got a 06 f150 and its got a 2.5 inch leveling kit and the rear end sags just a lil. Is the 1.5" rear AAL going to lift the rear too much or will it be perfect?
looking at this one:
http://www.suspensionconnection.com/...dd-a-leaf.html
Old Oct 31, 2011 | 11:15 AM
fx4210's Avatar
4x2 or 4x4, if its 4x2 it should come out closer to level, i believe because of diffference in rear block height. if you want it perfectly level i would measure the diference on flat ground thats the what i did with my truck then just added a bigger block on my 2010
Old Oct 31, 2011 | 11:50 AM
RandomHero34's Avatar
the 4x2's do not have a block in the back. I doubt a 1.5" leaf will make it level, but it should be very close after the front and back settle.
Old Oct 31, 2011 | 12:23 PM
pizzaman711's Avatar
A 1.5" aal is gonna give it some rake back, probably about an inch if I had to guess.
Old Nov 1, 2011 | 11:42 AM
EsJayEs's Avatar
Try overload shocks in the rear. They're shocks with a variable-rate coil spring over them. Incredibly simple and very effective. Monroe makes a good set, and you can get them at NAPA or other places that sell Monroe shocks.
Don't know where in NC you are, but if you're close to Virginia Beach, I have a pair sitting in my garage for 04-08 F150 2WD.
Old Nov 7, 2011 | 09:40 AM
Trhlz1222's Avatar
its a 4x4 and im now located in ny. moved back to where im originally from, missed snow. would blocks be better then putting in another leaf?
Old Nov 7, 2011 | 11:39 AM
adding another leaf will make the rider stiffer. A block will not.
Old Nov 12, 2011 | 01:43 PM
Bugman1400's Avatar
I'm not interested in height, I'm interested in a softer ride. My '05 FX4 is about to kill me. Should I take out some springs?
Old Nov 13, 2011 | 10:15 AM
EsJayEs's Avatar
If you're trying to get a softer ride and haven't modified your suspension, you would be a good candidate for Firestone's R4Tech suspension system. It's not cheap, but it gives you a softer ride when there's no load and automatically adds support when you're hauling or towing.
http://www.firestoneip.com/site-reso...ochure%202.pdf
Old Nov 13, 2011 | 09:21 PM
Nitrox's Avatar
is this to much rake for you? I have the daystar 1" budget boost (which is almost the same height spacers as the 1.5" autosprings kits) and i just installed the readylift 3" rear block kit. my truck is an 08'
i figured with your front end being higher you still might have some rake in the back with the blocks.
Nitrox
