Sponsored by: CARiD
What is the difference between these two lifts?
Old Oct 11, 2011 | 12:06 PM
JrBowHunter's Avatar
I know they arent suspension lifts but I can't afford a suspension at this time. I'm wanting to lift it though. What size tires could I fit?
http://performanceaccessories.com/de...%20Lift%20Kits
http://www.performanceaccessories.co...ory=PLS%20Kits
Thanks guys!
Old Oct 11, 2011 | 12:13 PM
wandell's Avatar
One is a 3 inch body lift for the 97-03 F-150's while the other combines a 3 inch body lift with a coilspring spacer.
Old Oct 11, 2011 | 12:15 PM
The one with the coilspring spacer. Is it really going to lift it about 5" like it says? Which one would you get?
Old Oct 11, 2011 | 12:20 PM
wandell's Avatar
The body lift will lift the entire truck 3 inches. The coilspring spacer will lift the front of the truck 2 inches. So this would lift the front of a 4x2 a total of 5 inches and the rear 3 inches, which should level the truck. A lot of 97-03 4x2 owners run this setup.
Old Oct 11, 2011 | 12:26 PM
So your saying that buying the one that has the 5" would level it and make it raised about 4 inches? Also if I got this would you guys get different wheels and tires?
Old Oct 11, 2011 | 12:30 PM
wandell's Avatar
No, I'm saying the 5 inch kit will raise the front of the truck 5 inches and the rear 3 inches.
Old Oct 11, 2011 | 12:32 PM
But that would level it out? To me I think my trucks seems pretty level. I might take a picture and upload it later.
Old Oct 11, 2011 | 12:43 PM
06yz250f's Avatar
if you have rake and want it gone, get the 5".
if you have no rake, get the 3" and leave it be.
not that difficult, you can always add the coil spacer later on.
Old Oct 11, 2011 | 01:20 PM
what do you mean by having rake?
Old Oct 11, 2011 | 01:59 PM
speedfourfan's Avatar
Your trucks front end will sit lower then the back. That's what he means by rake
Old Oct 11, 2011 | 02:00 PM
06yz250f's Avatar
http://lmgtfy.com/?q=what+is+rake
look at the 3rd noun definition
Old Oct 11, 2011 | 02:06 PM
azmidget91's Avatar
If you want a 5" lift for cheap get the one that say 5" level then get a 2" add a leaf, to get your "rake" back
Old Oct 11, 2011 | 02:20 PM
pizzaman711's Avatar
Just so you know install will run you about 550+ for a body lift so if your trying to do save money I'd plan on doing it yourself. And if you want it level get the 5" kit, otherwise get the body lift. And 33x12.50 tires. If you want 35's you'll need a bare minimum of 6" with a pretty decent amount of trimming and the perfect size wheel.
Old Oct 11, 2011 | 02:23 PM
06yz250f's Avatar
which for the price of all of that, i bet suspension would come out the same price.
5" spring tech is $550, that'd be the route i'd be going over a body lift.
Old Oct 11, 2011 | 02:59 PM
06yz250f, I just got this truck and I don't know much about them since it is my first vehicle. You dont have to be a *******, I know how to use google. Im not lazy either, I will outwork your *** anyday of the week. By the way thanks to everybody else who are helping.
