Different shocks needed?
I have put 33" tires on my truck recently from the 275 that were on it. Do I need to get some aftermarket shocks to handle the tires? Will the stock shocks wear out or cause any major problems? Any advice would be appreciated. Thanks
If you didn't add any lift or less than like 2.5" than the stock shocks will be fine. Eventually they'll wear out but not a noticeable increased rate. Now your balljoints will wear a little faster but again not a noticeable increased rate.
Test the shock by pressing down on the truck and seeing how much it rocks. Check the tires for cupping (tire bounces on road due to weak shock, tire then gets cupped)
Yes at 60k you will notice a big difference, especially if you go with a quality shock.
Best shocks would be Bilstein, Rancho, and some others, (can't remember name at the moment). These are not cheap, expect $100+ per shock for the fronts and a bit less for the rears. Good shocks would be Monroe (like the Gas-Magnum and some of their others meant for trucks) and Gabriels. Not sure of the cost for these, but would be a good bit less than the others. I have had Bilsteins and liked them. They made a big difference on my vehicles.
Install of the rears is easy. Do them yourself. Fronts are tougher as they require a spring compressor. I would expect someone would charge 1/2 to 1 hour labor per shock on the front.
