Sponsored by: CARiD
leveling 2011
Old Sep 7, 2011 | 08:26 AM
bhorc's Avatar
leveling 2011
What is the best leveling kit for a 2011 supercab? How high can I go with out runninging into problems.
Old Sep 7, 2011 | 08:47 AM
fx4 for life 79's Avatar
Id do a 2.5" autospring with aal or block in the rear or just do a 2" up front and be done with it
Old Sep 7, 2011 | 09:08 AM
pizzaman711's Avatar
Yea what he said^. Just don't go over 2.5".
Old Sep 7, 2011 | 12:30 PM
wandell's Avatar
Right. All of the spacer lifts are about the same, but some are way overpriced (Readylift). Just don't go over 2.5 inches or your ball joints will not last.
The best, but most expensive option is replacement coilover shocks, like Bilstiens. Not only do you get to level your truck you get a much better shock.
Old Sep 7, 2011 | 01:15 PM
bhorc's Avatar
Thanks for the info
Old Sep 9, 2011 | 02:19 PM
T_S_S's Avatar
Former Sponsor
You can also use Belltech's Lifting Strut
Old Sep 10, 2011 | 10:43 AM
bhorc's Avatar
is there a difference in the machined aluminum spacer vs the steel welded space?
The solid aluminum looks like it would hold up better than the 1/4" steel,
Old Sep 10, 2011 | 03:45 PM
I'd go with the 2" Autospring, Hell Bent or Top Gun. they're all about the same. 2" Autospring in front with stock height rear on mine. Rides great.
Old Sep 10, 2011 | 04:13 PM
wandell's Avatar
A spacer is a very simple, low-tech item. Some people make them out of different material as a marketing gimmick or they believe one is better than the other. Bottom line is they all work the same. If you like aluminim better, go for it.
Old Sep 20, 2011 | 08:03 AM
bhorc's Avatar
what is you use a new strut that is 2" taller like the quick lift with a 1" space, will the ball joinst still not last?
