Sponsored by: CARiD
Lower Ball Joint question
Old Aug 30, 2011 | 01:27 AM
97XL's Avatar
Ok so I finally figured out why I get a vibe between 80-110kph. Turns out the pass. side upper control arm was shot and so are the lower ball joints. I got the arm fixed cuz thats all I could afford at the time but my question is this.
Since as far as I know the ball joints are original and if I replace them should I go with a normal set of ball joints or get a set that are slightly oversized 0.006" for worn lower control arms? The mechanic never mentioned the lowers at all.
Old Aug 30, 2011 | 08:06 AM
pizzaman711's Avatar
Go with moog oem replacements, they're greaseable.
Old Aug 30, 2011 | 11:50 AM
MossyOak3006's Avatar
that's what I did
Old Aug 30, 2011 | 04:29 PM
Definitely don't go bigger than what's recommended, if it's bigger chances are it won't fit right and that will lead to more problems down the road.
Old Aug 31, 2011 | 01:00 AM
97XL's Avatar
Thanks for the replies. I planned on going with Moog, they have two styles, normal size & oversize, cost difference is about $2.
