Sponsored by: CARiD
2011 FX4 rear block removal questions
Old Aug 25, 2011 | 06:06 PM
BLKFx4Screw08's Avatar
Hello everyone, I just picked up a 11 f150 screw and would like to level the truck by removing the rear lift blocks but have a few questions. First, what all do I need to get to do the process, just new U-bolts?. Will I need an alignment after I take the blocks out? Only reason I want to go this path instead of raising the front end is because this is a daily driver and dont want bigger tires, im fine with the stock tires just would like it level. Thanks for any info on this.
Old Aug 25, 2011 | 06:28 PM
20eleven1fifty's Avatar
From my experience, it shouldn't require any alignment. Go for it!
Old Aug 25, 2011 | 06:41 PM
GS357's Avatar
Should be straight forward swap with no alignment needed
Old Aug 25, 2011 | 06:43 PM
So I would need the 2wd Ubolts and thats all? Just sit the leafs right down on the axle?
Old Aug 25, 2011 | 06:45 PM
06yz250f's Avatar
correct.
Old Aug 25, 2011 | 06:56 PM
Cool, ill go ahead and order some new u bolts now and see how it goes. Thanks for the help.
Old Aug 25, 2011 | 09:08 PM
topofffun's Avatar
Ive seen people use drop shackels instead I wouldnt rule that out
Old Aug 30, 2011 | 09:57 AM
BMWBig6's Avatar
I'm only familiar with the 2WD configuration, but would just removing the blocks effectively change the pinion angle of the driveshaft (causing vibration or premature wear)? Or does this not apply to 4x4 drivetrains?
Also, how much is payload reduced by removing the blocks?
Old Aug 30, 2011 | 10:23 AM
bkrug92's Avatar
I lowered the rear of my 2010 4X4 Screw with 2" lowering shackles and had a vibration. I took them out and have the stinkbug look again. I will try again later with some pinion shims next time.
Old Oct 27, 2011 | 02:13 PM
ridged43's Avatar
2011 Lariat 4x4 - Wondering if anyone has done this successfully and what were the final results? I looked at the blocks on mine and it appears they are drilled and tapped for a bracket that supports the brake line on each side. Did you support them another way?
Old Aug 24, 2012 | 08:51 PM
fordfan1964's Avatar
I'm trying to do this same thing on my 2008 limited, but the dealer is being a **** about helping me find the correct U-bolts. Does anyone have part numbers for the correct U-bolts? Something about him not being able to find parts without a vin number...
