Sponsored by: CARiD
spindles
Old Aug 9, 2011 | 11:26 PM
mote88's Avatar
spindles
Is there anyway to get just the spindles? I have the 6 inch spindles tht come with the 6 inch procomp lift but i need or want 8 inch spindles...No were i could get them? Thx for any help BTW trucks an 05 4x4
Old Aug 9, 2011 | 11:45 PM
pizzaman711's Avatar
Spindles? I don't think you have a 6" spindle. And I know for a fact no one makes a 8" one. I think you mean spacer since your truck is an 05. And no most people do not want a 8" spacer so I don't think they make one, it's not good for the angles and what not.
Old Aug 10, 2011 | 12:01 AM
mote88's Avatar
the spindle is what the upper control arm bolts on too and yes its the one tht comes with a 6 inch lift and i need one 2 inchs taller if i could find one
Old Aug 10, 2011 | 12:04 AM
mote88's Avatar
im not talking about a coil spacer or a leveling kit if thts wat ur talking about
Old Aug 10, 2011 | 12:39 AM
Buxton91's Avatar
He's telling you that the spindle doesn't actually provide 6 inches of lift. Esentially your lift comes from the six inch strut spacer. To get 8" you would need to swap out the 6" spacer for a set of 6" coilovers and a 2" leveling kit.
Old Aug 10, 2011 | 12:52 AM
Yes, I know what a spindle is. But no your truck uses a 6"strut spacer assuming it's the pro comp stage 1. Like Buxton said the only way to get 8" is to do coilovers and a 2" spacer.
Old Aug 10, 2011 | 01:51 AM
sbchris's Avatar
He is talking about the pro-comp cast spindle included with the lift kit. I'm not sure if it is 6 inches longer than stock, assuming it is 6 inch kit, but it's longer than stock. I'm pretty sure this idea wouldn't work. To make it work you would need to use a 8" drop bracket for the longer 8 inch spindle as the angle of your cv-axle and bottom ball joint will still be at it's max with a 6 inch drop bracket. No one makes a 8 inch spindle and the Rize kit is more like a 8.5-9" over the stock spindle, it also weights almost double the of the pro-comp spindle.
The only benefit you would have from this Frankenstein setup of running a longer spindle would be a better upper ball joint angle and that is it at a static ride height assuming you left the spring and spacer the same. Adding a longer spindle to a 6 inch kit won't let you lift the truck to 10 inches. In reality if you did use a Rize spindle on a pro-comp kit, the top of the Rize spindle would crash into the upper control arm upon compression. You'll also have more un-sprung weight on each side of the truck which would make it drive a more sluggish.
If you want an 8-10 inch kit buy a Rize or other brand that make big kits.
