04-08 Front end torque specs needed...
The parts came in and I'm about to rebuild the front end.
New Rancho Quick-lifts,
Moog UCA's,
Moog Lower Ball Joints,
A torque chart or link to one would be great.
Thank You
Marc
Moog UCA's,
Thank You
Marc
Torque Specifications
base, 5.4L Description Nm lb-ft
Wheel nuts 204 150
Jounce bumper-to-frame bolt 35 26
Wheel hub-to-wheel knuckle 200 148
Tie-rod end nut 150 111
ront axle-to-wheel hub nut 27 20
Upper ball joint nut 115 85
Upper arm-to-frame nuts 150 111
Lower ball joint nut 150 111
Lower arm-to-frame bolt and 300 222
Front shock absorber rod nut, 30 22
Item Specification Shock absorber upper 48 35
Shock absorber-to-lower arm 475 351
Wheel Track Stabilizer bar bracket-to-frame 48 35
bolts
Stabilizer bar-to-link nut 133 98
Stabilizer bar-to-link to lower 90 66
control arm nut
Anti-lock brake sensor bolt 18 13
2004 F150, 12/2003
204-00-4 Suspension System 204-00-4
SPECIFICATIONS (Continued)
Torque Specifications (Continued) Torque Specifications (Continued)
Description Nm lb-ft Description Nm lb-ft
Integrated wheel end bolt (3 12 9 Shock absorber, lower 90 66
required) Rear caliper bolts 32 24
Caliper anchor plate-to-wheel 200 148 U-bolt nuts (light duty) 115 85
knuckle bolts
U-bolt nuts (heavy duty) 250 184
Caliper-to-anchor plate bolts 32 24
Spring/frame nut (front) 300 222
Rear Suspension
Spring/shackle nut (rear) 133 98
Shock absorber, upper 90 66
Spring shackle/frame nut 133 98
2004
Wheel nuts 204 150
bolts
control arm nut
2004 F150, 12/2003
knuckle bolts
Rear Suspension
2004
