Sponsored by: CARiD
35's on a 2.5 inch level?
Old Jun 10, 2011 | 07:13 PM
Big_Smokey's Avatar
you have to watch the aggressive treads on the MT also when you are running stockers also..just in case nobody mentioned that. could rub your control arms
Old Jun 15, 2011 | 09:44 AM
KingRanch4Life's Avatar
My current KR has:
22X9.5 Rockstars
325/50/22 Nitto Trail Grapplers
2.5 AS leveling Kit
-11 offset
No rubbing and no plastic trimming.. Did have to remove the factory running boards though. No control arm rub. The old King Ranch(white) don't remember offset but had the same size tires and rim.. Rubbed on control arm, center frame, plastic trim in the front and rear.... All in all, it depends on your truck.. You may rub, you may not....
Old Jun 15, 2011 | 09:45 AM
Originally Posted by KingRanch4Life
My current KR has:
22X9.5 Rockstars
2.5 AS leveling Kit
-11 offset
Old Aug 14, 2011 | 03:22 AM
projekt4's Avatar
anyone have any info on running a 1" rear block in place of the factory 2" rear block? still able to clear 315/70/17's and have a nice level stance?
Old Aug 14, 2011 | 05:08 PM
philly164's Avatar
325/65/18 AS 2 1/2" with 3" rear blocks
Old Aug 15, 2011 | 08:00 AM
fx4210's Avatar
I ran my 2.5 level with a rear block and 35x12.5r20 with the stock rims. it worked out well you wand +5.5 backspacing as too much backspacng and you'll rub on the Fenders, and too little backspacing and you'll rub on the frame... like I did
This my truck with the level,
