Sponsored by: CARiD
another level kit ?
Old Apr 9, 2011 | 08:11 PM
SMc's Avatar
SMc
another level kit ?
hey guys new to site been lurking for a little while i know level kit questions have been beat to death but i gotta ask i recently had the 1 1/2 inch level kit installed on my 2010 screw lwb and ended up with 2 inches higher now the truck is nose up by 1/2 inch its too late now to remove and have since ordered 1/2 spring pack spacer but i really did not want mess the rear and spend more to do it just curios if anyone had the same issue or maybe i was sent the wrong kit thanks
Old Apr 9, 2011 | 08:17 PM
06yz250f's Avatar
it's common to get a little extra lift from the spacers.
Old Apr 11, 2011 | 08:15 PM
MossyOak3006's Avatar
putting a 1 inch taller block in the back to level it up shouldn't cost you but $50 or so. All you need is 2 blocks and new u-bolts. You can put them on in probably 2 hours with nothing but a jack, lug wrench to take the tires off, and a wrench for the u-bolts.
Old Apr 11, 2011 | 10:43 PM
FireBean's Avatar
Just curious... what kit did you use? I am about to order one and can't decide which one to go with. Thanks!
FB
Old Apr 12, 2011 | 07:24 PM
SMc's Avatar
SMc
i used an auto spring 1-1/2 front spacer and ended up with 2 inches of lift my tucks rear block is smaller than most for some reason kevin at auto spring is a good guy to deal with and gave me options to use and i decided on the 1/2 spring spacer instead of the rear block it should sit dead level after spacer
