Sponsored by: CARiD
balljoint time
Old Apr 2, 2011 | 01:36 AM
chiaronate's Avatar
balljoint time
My lower balljoints are due for replacement and i plan on doing the job myself. does anyone know how much torque is required to remove and put in these things? i mean approximately how much torque would i need from an impact wrench?
Old Apr 2, 2011 | 05:53 PM
alex7191's Avatar
they're pressed in. you use a press
Old Apr 2, 2011 | 07:44 PM
chiaronate's Avatar
Right but an impact wrench can be used with the press. im guessing my 1/4 inch impact driver rated at 133 ft lbs wont do it, how much torque will place it where it needs to be? I like things to be as easy as possible and need to know before buying an impact wrench.
Old Apr 2, 2011 | 08:40 PM
Jesse H's Avatar
If your compressor doesn't have enough juice it's still easily done by hand with a 1/2" ratchet. Just did it today.
Old Apr 2, 2011 | 08:46 PM
chiaronate's Avatar
Ok thanks jesse my impact driver is a cordless. i called advance and someone there said 110 should do it, its good to know a ratchet would be easy if the impact driver doesnt work.
Old Apr 2, 2011 | 09:04 PM
Gotts2BMe's Avatar
impact makes it so much easier. If you can't get it pressed all the way in use a ratchet with a snipe or breaker bar to get it totally in. Make sure you press it in straight.
Old Apr 2, 2011 | 09:11 PM
rho1998's Avatar
Beat mine out with the BFH and put the new ball joints in the freezer over night and they tapped in real easy
Old Apr 2, 2011 | 10:03 PM
chiaronate's Avatar
I have to claim ignorance here, i dont know what a snipe is. i thought a press would put it in straight automatically.
Old Apr 2, 2011 | 10:08 PM
chiaronate's Avatar
That sounds like a good idea thanks ill do that.
Old Apr 2, 2011 | 10:23 PM
Ford12508's Avatar
The impact driver probably doesn't put out 133ft-lbs just because thats what it is rated for. If those numbers were really true, it would take 4 of me to remove my lug nuts. I think you are going to have to resort to using a ratchet.
