Icon Shock system.
Icon Shock system.
I need to replace my shocks (ranchos quick lift) and springs.
2005 SCrow 5.4, wheel 9x18 0 offset, tiers 325/60/18.
What is the input on the ICON system? Did anyone try it?
http://www.iconvehicledynamics.com/s...pension-System
Appreciate all the help I can get.
Thanks for all the replays.
What about the tier wheel that I have.
Will that be ok?
I am in the United Arab Emirates worentys is not the easy.
Will that be ok?
I placed the order on the icon kit.
Thinking of ading total chas witch are available localy hear. What do you think?
http://www.chaosfab.com/80501.php
Everything else should be fine if you are just getting UCAs and coilovers. The coilovers change the geometry of you front end when you add the lift and then the UCAs from Total Chaos help correct the geometry because they are longer
