Sponsored by: CARiD
Need input.
Old Mar 23, 2011 | 04:08 PM
RamiusDC's Avatar
Need input.
I recently had a 6" stage 1 pro comp lift installed on my 06 f150. I noticed that the back sits a little lower than the front. What's the best way to remedy that? Thank You
Old Mar 23, 2011 | 04:41 PM
mdhawkin's Avatar
Add a leaf or taller blocks to the rear (avoid stacking) are the most common ways. Do a quick search on it, tons of post covering it.
Old Mar 23, 2011 | 05:03 PM
06yz250f's Avatar
if you use your bed go with an AAL your rear of the truck will stiffen up but won't sag as much when you have something in the bed.
if you go with a block get one huge one to get rid of the stacked blocks (pro comp uses your original block + their block to get rear lift height)
if you don't do the install yourself both will come out to similar prices.
Old Mar 23, 2011 | 05:18 PM
RamiusDC's Avatar
Thanks for the input guys. I think I'll go with the add a leaf due to the fact that during spring and summer I haul my dirt bike everywhere I go.
Old Mar 23, 2011 | 05:32 PM
06yz250f's Avatar
dirtbike won't mess with it much, i'm talking an actual load of 800+ pounds.
make sure you have a long enough ramp for your bike though, it's a pain loading a dirtbike in the bed by yourself on a lifted truck
