Sponsored by: CARiD
rear blocks?
Old Mar 19, 2011 | 04:05 PM
truckin150's Avatar
rear blocks?
i got a 4x4 2008 f150, i got the 2.5 inch leveling kit on it now but would like to add 1-1.5 inchs to the rear for when pulling a trailer it dosent sag the truck down so bad, woundering what size blocks would i need to do so? not sure how big the factory blocks are, any addvise
Old Mar 19, 2011 | 04:11 PM
used2vtec's Avatar
I believe your stock rear blocks measure 1.5 inches. I would at least go for a 2.5 but no more than a 3 inch block. You can always install an add a leaf but it will stiffen up your ride. The only way for you to figure out which block is best for you is measure with and without a trailer and see how much rear lift you need.
Old Mar 19, 2011 | 04:12 PM
Big_Smokey's Avatar
I did an AAL on my 2006. I needed an inch to bring it level. I wanted to be a touch higher in the back. i achieved what i wanted, plus i could put more weight in the bed and it wont sag as much.. I guess what im saying is you will still sag the same with a bigger block, you will just appear to be level, Its a much easier solution to add a block. I cant remember what size the rear block is now...1.5" maybe?? I thought guys were replacing those with 3" blocks to achieve what you are looking for if i remember correctly. My 2010 has a 1.25" block.
If you do AAL make sure to do the Long leaf, as it wont be as harsh a ride. I actually liked the ride better then when it was stock, F_ast did this also and said the same thing...So there you go
Old Mar 19, 2011 | 04:22 PM
truckin150's Avatar
are the blocks cheaper then the leaf? tryin not to spend to much but i want somethin i can depend on
Old Mar 19, 2011 | 04:28 PM
used2vtec's Avatar
the blocks will def be cheaper and easier to install.
Old Mar 19, 2011 | 04:30 PM
truckin150's Avatar
any reccomendations on where to find 2 to 2.5 inch blocks for an 08 f150?
Old Mar 19, 2011 | 05:59 PM
Big_Smokey's Avatar
my leafs were like 115 bucks or so. for long ProComp leaf springs... and they are a pain to install, but they were worth it to me.
Old Mar 19, 2011 | 07:15 PM
greencrew's Avatar
The factory blocks on your 08 4x4 are 2". The actual measurement is 1 15/16". I would think your best bet is to prevent the rear sag with something like air bags.
