Sponsored by: CARiD
PLEASE HELP 06 front differential bracket weld broken at frame
Old Feb 2, 2011 | 10:15 PM
PLATINUMSAL06's Avatar
My differential mounting bracket that is welded to the frame broke off today. Has anyone heard of this happening and how deep do I have to go as far as removing front end pieces to re-weld? Can I just re-weld this to the frame? Will it have to be in a very specific spot to be aligned with shaft? Will i damage it further if I drive it in 2wd untill repair is made? I have soo many questions?
Old Feb 3, 2011 | 12:37 AM
Buxton91's Avatar
I would think that you could just re-weld it back in the original spot.
Old Feb 3, 2011 | 12:59 AM
06 broken differential bracket weld
That is what I plan to try. Any Ideas as to what parts need to come off to get to that spot on frame? As far as I can tell, The entire differential has to come out first. To get that out it looks like to Skid Plate, Wheels, Brakes, Rotors, Hub Assembly, CV Boots/Joints, Axle Shafts Etc. must all come off. I was hoping that i would not have been the first to experience this. Thanks for the input
Old Feb 3, 2011 | 09:55 AM
1santacruz1's Avatar
Do you have a picture?
Old Feb 3, 2011 | 10:42 AM
Yes I do have pictures however you will have to be familiar with the location of the front differential to make sense of the photo. There is not very much space to get to or even see where the broken weld is located. The broken weld is in the center of the photo. I am trying to get the pictures from my phone on to the computer now
Old Feb 3, 2011 | 11:38 AM
Great thanks. I have read on another forum of this happening, causing a clunk in the front diver side in 4wd when changing from forward and reverse, which is what mine is doing.
My email is ogarajef@luther.edu if you have problems downloading pics.
Thanks a ton
Old Feb 11, 2013 | 01:27 PM
lplp52's Avatar
I have the same problem, i noticed that my axle is moving quite a bit and is doing the same things.. how did you make out and can i see some pics of this .. thanks
