Sponsored by: CARiD
alignment problem after leveling kit
Old Jan 22, 2011 | 10:11 PM
newfordguy10's Avatar
I have just installed a 3 inch leveling kit and took my truck to fire stone for alignment. They said that it could not be aligned to factory specs and cause my tires to wear. Is this true? or do i need a second option? Any help would be appricated this is driving me nutts
Old Jan 22, 2011 | 10:21 PM
freekyFX4's Avatar
If the Camber is off, you may need an alignment kit.
Old Jan 22, 2011 | 10:28 PM
my camber is setting left front at -.07 and -.09 front right. How bad off is this?
Old Jan 22, 2011 | 10:31 PM
freekyFX4's Avatar
Not sure what the range is. Did you have them check to make sure you ball joints aren't worn? What are the specs of your truck?
Old Jan 22, 2011 | 10:33 PM
Fill in/tell us your vehicle information. It will help people answer your questions better. Right now I'm thinking you drive a riding lawnmower.
Old Jan 22, 2011 | 10:35 PM
its a 2010 f150 4x4, right now im running 265's and wanting to get the kinks out before i get my 35's.
Old Jan 22, 2011 | 10:57 PM
freekyFX4's Avatar
Well, a 3" leveling kit is a bit extreme. I thought the new trucks had less rake and required only a 2" to level the truck. I really am not surprised though that your camber is off. The camber sleeves cost $50-$100 plus installation plus the alignment.
Old Jan 22, 2011 | 11:00 PM
thanks for the info, i will start looking for some camber sleeves.
Old Jan 23, 2011 | 08:34 PM
whats the differnce between camber sleeves and a camber kit?
