Sponsored by: CARiD
Fabtech lift help!!!!
Old Jan 18, 2011 | 10:20 AM
Tarpon-Screw's Avatar
Hey guys I bought a used fabtech lift. I wanna replace all the bushings before I install it. Where would I get bushings from? Fabtech? Please help
Old Jan 18, 2011 | 10:23 AM
StoveTop's Avatar
Not sure why there's a question. If you want them to fit properly, call Fabtech. I would be surprised if they didn't help you with new bushings.
Good luck.
Old Jan 18, 2011 | 10:29 AM
b2therad's Avatar
Calm down killa.. the way you worded the title seemed like somthing bad happened or something. Fabtech will sell you anything with their name on it. They will sell you everything from a bolt or washer to a spindle or crossmember. All you have to do is call them up and tell them what you have, and they will pull out a packing list for whatever lift you have and pull the parts numbers for the bushing kits.. problems solved.
Old Jan 18, 2011 | 11:16 AM
Ok thanks for the fast replies!!! That's what I kinda figured..... Just wanted to double check
Old Jan 20, 2011 | 12:29 PM
Thomas_W's Avatar
This is going on your 2001 right? From what i can remember, my fabtech 6" susp. lift didn't come with any bushines. All of the bushings are installed in the factory upper/lower control arms. So if your wanting to replace those, you'll need to go to a auto parts store.
Old Jan 20, 2011 | 12:48 PM
GATOR CREW's Avatar
2009 F150online Truck of the Year
Hey Tarpon, what size lift did you get?
Old Jan 21, 2011 | 08:04 AM
6". Looking to pick up a 3" body lift and gap gaurds!!! Then gears and tires. Maybe some fuel 20x12s
Old Jan 21, 2011 | 05:30 PM
Thomas_W's Avatar
make sure you get some decent shocks to put on with the lift. The fabtech oil-filled shocks do not last long, and even when they are new they still suck.
Old Jan 21, 2011 | 05:55 PM
sledman62's Avatar
x2 on that one
Old Jan 21, 2011 | 09:35 PM
Yeah the kit I got didn't come with shocks so I'm thinking about the 5100's
Old Jan 21, 2011 | 11:32 PM
b2therad's Avatar
Old Jan 22, 2011 | 02:22 AM
My buddy has a gold xlt supercrew With the fabtech + body lift with 37s. I thinking 38x15.5's!!!!!
Old Feb 26, 2011 | 12:08 PM
twintower's Avatar
Hey I bought mine used too bought all the bolts and stuff I needed at 4wheel parts just call and talk to them .....
