Sponsored by: CARiD
Tire sizes 36's, 37's for 18" wheel
Old Jan 13, 2011 | 08:13 PM
96grimreaper's Avatar
JUST REALIZED I put this in the wrong section, please move to correct section. Sorry and Thanks.
Ok, so I told myself I wasn't going to upgrade my Nitto Trail Grapplers until they wore out but I want bigger already.
Currently a 6" sitting on 295/70/18's which measure 34" on the truck. I am thinking 36x12.5, 36x13.5 or maybe 37's. I know I'll need some more lift for 37's but my issue is who makes these tires for 18's? The biggest trail grappler is a 35x12.5 but I want taller.
Here's what I'm working with:
Now, if I do go with 37's can I just throw the 4" spacer on top of some 5100's and do aal?
2 things:
The nittos were put on when I just had the leveling kit-didn't plan ahead
The KC's were replaced with two Hella 700's with HID's
Old Jan 14, 2011 | 10:13 AM
Ponyboy24's Avatar
I think your rig looks great!
Does BFG make that size??
Old Jan 14, 2011 | 10:35 AM
BFG makes a 36 except BFG's run really small and they only measure out to be a 35. I want the tire to measure out to be right around 36 when mounted on the truck so factoring in the squish I may have to buy 37's.
Old Jan 15, 2011 | 10:38 PM
lomo2surf's Avatar
so whats the difference (noob question) between 295/70/18 and a 35x12.50x18 - is it just the rims and width size?
Old Jan 19, 2011 | 12:19 PM
Big_Smokey's Avatar
34x11.60x18 vs...... 35x12.50x18
Old Jan 19, 2011 | 12:40 PM
RandomHero34's Avatar
so let me get this straight, you want to put a 4" spacer on top of the front struts? or are you talking about a 4" block.
Old Jan 19, 2011 | 02:30 PM
The rough country lift uses a spacer on top of the factory strut instead of a replacement coil-over.
What I was thinking is putting the rough country spacer on top of some 5100's cranked up 2". Then do an aal instead of a bigger block.
Old Jan 19, 2011 | 02:47 PM
ok now i see what your saying. im far from an expert on lifts, but i dont see why that wouldnt work.
Old Jan 19, 2011 | 03:14 PM
Big_Smokey's Avatar
you have a 6" lift now. It uses a spacer and factory strut. hmm. sounds like it would work. how big is the spacer thats on it now? couldnt you just do a coilover by itself cranked up to two inches? Price im sure is cheaper how you are talking about doing it.
Old Jan 19, 2011 | 06:51 PM
bossman15's Avatar
You can crank the Bilstein 5100's with the stock lift spacer and get 8 inches of lift. Or get Bilstein lift shocks which replace the spacer and slap a leveling kit on top (if the rcx kit for the 09+ allows for a leveling kit on top). Either way you are getting 8 inches but the second method looks and probably drives better.
Old Jan 19, 2011 | 07:16 PM
The rcx kit would allow the lift shocks plus run the 2" spacer I pulled off to put on the lift. Essentially what the rcx kit does is drops the diff and a arm, uses an aftermarket knuckle to allow for the 4" spacer to go on top of the factory strut.
I haven't priced out the difference between the 5100's and aftermarket coil-overs yet.
I still haven't found a tire in the size I want yet. I think I'll have to run a spacer or get a different wheel if I go 13.5 wide though.
Maybe I'm just over looking them but I can't seem to find the lift 5100's anywhere!!! Does anyone have a link or suggest where to buy?
Old Jan 19, 2011 | 09:30 PM
Big_Smokey's Avatar
how wide are your wheels now.. 8.5" 13.50's would prbably be ok. may balloon just a little bit.
Old Jan 19, 2011 | 10:01 PM
9"
The offset is probably the issue. +25mm w/ 5.98 backspacing.
Old Jan 19, 2011 | 10:21 PM
Big_Smokey's Avatar
yah that'll probably rub a little bit inside. im sure someone here has the setup similar to what you are doing.
Old Jan 20, 2011 | 09:35 AM
03Fx4JD's Avatar
Great looking truck!!!!
