Sponsored by: CARiD
Ball Joints
Old Dec 11, 2010 | 11:27 PM
Wiplash06's Avatar
Ball Joints
Was wondering if anyone knows about ball joints. I have to replace the bottom ones on both sides. Is there a different brand to get or should i get the stock ones again
Old Dec 12, 2010 | 12:39 AM
fatty4x4's Avatar
Motorcraft ball joints arent serviceable so my personal preference is MOOG ball joints. A good site for these parts is www.rockauto.com . I decided to go with a new lower control arm instead of trying to fit a ball joint into the old lower control arm. You may want to research what is involved replacing just the ball joint into the factory lower control arm.
Old Dec 12, 2010 | 09:30 AM
wookie13's Avatar
X2 for the MOOGS
Old Dec 12, 2010 | 01:53 PM
password's Avatar
can you not tap them and install a fitting. obviously this would need to be done befor they go bad. I did this to my explorer and it worked awsome.
Old Dec 12, 2010 | 02:11 PM
wandell's Avatar
The newer Motorcraft ball joints have grease fittings. Also, if your lowers are worn out, the uppers can't be far behind. Might as well replace all four.
