Sponsored by: CARiD
Torsion Key Question
Old Nov 16, 2010 | 06:06 PM
speedyturtle's Avatar
Hey guys, I just got a 2002 fx4 and want to level it. But first Ive got a question about the torsion keys. Ive read that turning the stock torsion keys makes the ball joints(suspension parts) wear quickly. Does that also go for aftermarket torsion keys? I just want to be able to fit 33's.
Old Nov 16, 2010 | 07:22 PM
Galaxy's Avatar
Cranking the stock ones don't hurt a thing, even all the way to the stops. Aftermarket ones are another story. Stay clear of them...period. Yo can fit 33's just fine with the stock keys cranked up.
Old Nov 16, 2010 | 08:43 PM
Will i need to do any trimming for the front? I dont want to crank em all the way up just to be careful, but I will crank them some
Old Nov 16, 2010 | 10:28 PM
wandell's Avatar
That depends on what wheel you use. If you use a 10 inch wide wheel you will have to trim some plastic off the front bumper's lower valance.
Old Nov 16, 2010 | 10:46 PM
fordordie1's Avatar
ok so i want to do this and i looked under my truck and one key is cranked more then the other (wasnt on level ground) would i crank the shortest all the way and crank other same amount or crank both all the way?
Old Nov 17, 2010 | 02:59 AM
Galaxy's Avatar
My technique is crank the both full to the stop. If the truck doesn't sit level, simply back off the side that's too high until it's level where you like it.
Old Nov 27, 2010 | 09:36 PM
fordordie1's Avatar
will it be that noticeable>? also my *** end has drooped a little (i noticed) i been goin to dump with really heavy loads. how would i fix that
Old Nov 27, 2010 | 10:24 PM
wandell's Avatar
You can lift the rear an inch or so by installing taller lift blocks.
Old Nov 29, 2010 | 05:00 PM
fordordie1's Avatar
what about Shakles(spelled wrong i knos) what would be better. i cranked them yesterday and the truck seems 100% level
Old Nov 29, 2010 | 09:51 PM
wandell's Avatar
Very few lift shackles are available for our trucks. But lift blocks are available everywhere.
Old Nov 30, 2010 | 06:03 PM
chiefFX4's Avatar
if you want to stiffen the rear up a little, install an add-a-leaf. this can add 2" of lift and help with the sag.
when cranking torsion bars always do the same amount of turns per each side. start with 2 full turns on each side, drive around the block and check to see if you like the height.
get an alignment when things are said and done.
Old Nov 30, 2010 | 08:31 PM
Glen R's Avatar
Any ball park, idea on much lift a full 2 turns will yield? I am putting 1" spacers in the rear of my Expd, and will be adjusting the torsion bars up.
Old Nov 30, 2010 | 09:58 PM
wandell's Avatar
I'd guess about an inch.
Old Nov 30, 2010 | 10:21 PM
Galaxy's Avatar
Not true, and not required. The suspension doesn't know how many turns are cranked in nor how far that bolt is in or out. My trucks bolts are drastically different. Re-read my post/instructions above...best way to do it. Cranking the bolts evenly doesn't guarantee a level truck.
