Level Kit Angle Corrections?
I have a '06 Lariat 4WD. I put on a ReadyLift 3" Level (Front & Rear)... which is not so level (rear is now lower)... anyway. I don't like the angles of the control arms, the uppers have virtually no room to travel without hitting the coils. After quite a bit of searching I believe there is no option of longer control arms. Is there spindle options?
I put on the level kit to buy time till I can afford a full 6-8" lift. I'm looking for cheap fixes.
Having now replaced all ball joints (getting ripped off on 2) I'm hoping to just get buy till spring/summer when I should be able to do the full lift.
These are the strut spacers, right? I probably wouldn't go much higher than 1.5 or 2" with a strut spacer, simply because the ball joint will be nearly maxed-out and/or the UCA will hit the coil spring (as you found out). That and having no down travel makes the ride suck.
With a 1.5" or 2" strut spacer and factory blocks in the rear, you should be level or nearly-level. You could also go with a uniball upper control arm, but that would still be pushing it with a 3" spacer.
That said, what's wrong with the "bulldog stance"?
