Sponsored by: CARiD
Daystar leveling kits
Old Oct 2, 2010 | 05:24 PM
hk45shooter's Avatar
Anybody have these on their trucks? How do you like the ride after installation, about the same as stock, rougher? Do they eventually wear out & cause the front end to sink since they are polyurethane?
I have a 2004 4x4 that I want to put a leveling kit on & would like opinions of the Daystar kit. If the Daystar is a no go, what do you all recommend? I would prefer something that does not change the ride quality of my truck too much.
Thanks.
Old Oct 2, 2010 | 11:14 PM
wandell's Avatar
Daystar makes quality products. You don't have to worry about the urethane they use wearing out. I had one of their kits on a Grand Cherokee for years. Honestly, none of the spacer style leveling kits for the 04-11 F-150's should change the ride as they are just a spacer that bolts on top of the coilover shocks.
Old Oct 3, 2010 | 02:09 AM
Thanks wandell. You have a very good point there, about not changing the ride quality.
I know I have read that you can fit 33's - 35's under a truck with a 2.5" leveler kit, but what about a truck with mudflaps? My truck has 275/65/R18's on it now & I think I would like to go to 33's, is there a tire conversion chart around here someplace, & would I have to take off my mud flaps? I would rather not take them off cause I live on a gravel road & they do do their job pretty well by protecting the paint. (I don't go fast on gravel roads)
Would I be able to get 33's in the wheel wells with a 2" kit? I don't mind a little bit of a rake, but the factory rake is ridiculous. Just looking at my options.
Thanks again.
Old Oct 3, 2010 | 10:55 PM
wandell's Avatar
Honestly, I'm not sure how the mudflaps would interfere with 35's. You shouldn't have any problems with a 33 inch tire with a 2 or 2.5 inch leveling kit. As for tire sizes, you can look at the manufacturer's websites for exact sizes. But for what you are considering, basically:
285/65-18 = 33x11.50
305/60-18 = 33x12.50
305/70-18 = 35x12.50
Old Oct 4, 2010 | 01:02 AM
AWESOME, thanks again for your help & expertise in answering my questions.
I will likely stay with a 33" tire when I get ready to do this, since it won't really affect my MPG by looking at the sizes you posted. Now I just have to make up my mind on either the 2" or 2.5" kit. Gonna go check out some of the "show me your __ leveling kits" type of posts.
Thanks again wandell.
Old Oct 4, 2010 | 08:08 PM
2006WFX4's Avatar
simple calculation for tire sizes. Example. 295/65-18 295*.65*2/25.4 + 18 = 33.1 will give you the height of the tire. Hope that helps your search for tires.
