Warped front suspension?
I ordered a 3" leveling kit for my truck over 2 months ago, installed it and wasnt happy with the results. My truck should be level but sits 1" lower in the front. some said I might have a warped suspension which is plausible. its an 04 F150 lariat 4x4 supercrew. my friend has the same truck and leveling kit, and his truck sits properly. i looked at the suspension and it looks normal as far as I can see. If anyone knows the problem, has had the same problem and/or can tell me how to fix the problem, it would be greatly appreciated. im wondering is this normal or is something wrong with my suspension. also i was wondering if the previous owner installed 2wd front shocks (how can i tell if they are 2wd shocks if they are?)
Thanks,
Chris
Thanks,
Chris
3" kits are generally not recommend by most members on this site. reason being it puts a lot of stress on the ball joints, which any leveling kit will do, but their pretty extreme on a 3". i have a 2.5" kit on my 04 supercrew and it sits perfectly level. 3" SHOULD make your truck sit level, or possibly even a little nose high, but it definitely shouldn't sag in the front at all. i dont know how you could tell if the shocks are 2wd, or if thats even possible on a 4x4 truck, so hopefully another member will chime in. the only reason i could think of that your truck would still have any front rake left after a 3" kit is if the previous owner installed bigger rear blocks or added a leaf spring to the your truck.
