Rim rubing on swaybar
I have a 01 SCrew lariat and i have a 1.5 daystar leveling kit on it. When i put the kit on i noticed some rubbing and after looking around i realized it was the rim rubbing the swaybar.
Has anyone else experienced this? and how harmful can this be to the truck?
i figured you were talking about the tire rubbing for some reason. did you get an alignment afterward? stock wheels?
you sure its the sway bar and not the tie rod end? don't know how that would be possible without changing the rims though.
if there is enough contact to cause grinding metal you need to get that looked at.
Yeah i still havent got an alignment so maybe that could help? if it stull rubs then i will take it in to the shop. And yes im positive its the sway bar. Its just at a full lock to the left. Also i do have the stock rims still
