Sponsored by: CARiD
5" block ? will it fit.
Old Aug 16, 2010 | 05:50 PM
bboybean's Avatar
A person is selling a 5" tapered block with this description
Blocks are sold in pairs
Standard 9/16" male pins with 5/8" female
All blocks are tapered for pinion adjustment unless noted
Black powder coating
will this fit? he said it should but I wanted to double check with you guys first. Thanks tons for any help
Old Aug 16, 2010 | 07:03 PM
HighOn22's's Avatar
Did they come off of an f150? What name brand are they? When I was looking for tapered blocks I was told no one made them for an f150 so I bought shims. Also which u bolts do you have now?
Old Aug 16, 2010 | 07:47 PM
bboybean's Avatar
Ill need new u bolts for sure, I dont know what theyre off of (buying off kijiji - like craigslist).
http://edmonton.kijiji.ca/c-cars-veh...AdIdZ220362875
Old Aug 16, 2010 | 08:30 PM
HighOn22's's Avatar
Are they double pin? I think as long as each block has two pins it should work. Most trucks blocks only have one pin, but ford has two.
Old Aug 18, 2010 | 12:14 PM
gearhead5225's Avatar
They do make tappered blocks for the F150, i dont know how big they make em though, i got a set of 4" ones on a a shelf in my garage. But ya those blocks should work just as long as you get big enough U-Bolts
Old Aug 18, 2010 | 12:16 PM
b2therad's Avatar
I have 5" blocks on my truck.
Old Aug 18, 2010 | 12:17 PM
Mikiedoo's Avatar
How is the ride quality with those?
Old Aug 18, 2010 | 12:23 PM
b2therad's Avatar
Its not bad. Its stiffer than up front though for sure. I think it depends on what kind of shocks you get also, and my shocks are pretty firm in the rear. Dont get me wrong though, its not bad at all. Its not choppy or anything, but you can feel speed bumps and stuff like that alot more.
Old Aug 20, 2010 | 03:31 AM
midwestoffroad's Avatar
Rough countrys rear fabricated blocks are 5.5" and tapered
but the 04 up will require dual pin the 03 and older would use a single 9/16 pin
