Sponsored by: CARiD
F150 Leveling Question
Old Jul 19, 2010 | 11:09 PM
F1502X4's Avatar
Hi, I have a 1993 F150 2X4 XL Long Bed 5.0L. I wanted to know whether or not a 4X4 leveling kit for the same year truck would work on my 2X4.
http://www.daystarweb.com/productdet...?productID=147
That is the link for the kit. If this kit is not compatible then what would you get to level out the truck?
Old Jul 19, 2010 | 11:19 PM
credurdead's Avatar
I would contact them direct, also consider Hell Bent Steel!!!!
Old Jul 20, 2010 | 07:35 PM
F1502X4's Avatar
Ok thanks. I have heard of hell bent steel but never really looked into it.
Old Jul 20, 2010 | 07:42 PM
F1502X4's Avatar
I checked out hell bent steel and they only do 2003 models and newer.
Old Jul 20, 2010 | 07:53 PM
credurdead's Avatar
bummer, sorry man, I love the way my truck sits after the level kit, i suppose there aren't too many companies that feel there is a need for aftermarket level kits for late models, THEY ARE WRONG!!!!!! Good luck with your search, I would post under the appropriate year section and see what others with the truck have found
Old Jul 21, 2010 | 05:55 PM
F1502X4's Avatar
If anyone else that reads this has any ideas feel free to offer them.
Old Jul 22, 2010 | 08:30 AM
Titan357's Avatar
does the 4X4 truck in that year/style sit higer in the front? if so could you swap front end parts to life yours? That would make it about level?
Just a thought.
Old Jul 22, 2010 | 04:49 PM
F1502X4's Avatar
Honestly I would not know %100 if it sits higher, but my dilemna is that I think the front end is different on a 4X4 as compared to a 2X4 since the leveling kit says it fits a 4X4 and does not say whether or not it would fit a 2X4. But I'm just going off of little information.
Old Jul 22, 2010 | 08:28 PM
wandell's Avatar
The 4x4 and 4x2 suspensions are different. I believe that Daystar makes coilspring spacers for your truck.
Old Jul 23, 2010 | 12:08 PM
F1502X4's Avatar
If you found one that would be great. I checked daystar and only found a 4X4 model coil spacers unfortunately.
Old Jul 23, 2010 | 12:09 PM
wandell's Avatar
Try e-mailing them.
Old Jul 23, 2010 | 12:23 PM
MudTerrain's Avatar
I'm sure there is a company that makes either coil spacers, or extended coils to level the older gen. F150's...
You may also need new camber/caster bushings to align the truck. There may not be enough adjustment in the stockers... You'll just have to see.
Old Jul 23, 2010 | 05:01 PM
F1502X4's Avatar
Ok, thanks for the info. I'll look into extended coils too. I never thought about that.
Old Jul 26, 2010 | 07:19 PM
F1502X4's Avatar
Ya, I found 2" extended coils online. Downside is that they cost $260 vs. about $130 for spacers.
Old Jul 28, 2010 | 12:07 AM
F1502X4's Avatar
Ok, I've been on google and found coil spacers for 1983-1996 Ford Bronco. The kit says it fits 2wd/4wd bronco's. I looked up the part numbers for the bronco coils and f150 coils for 1993 and the part numbers are the same. So they should work.
http://4wheelonline.com/Products.asp...oductID=154814
This is the link for the spacers.
