Sponsored by: CARiD
Rough Country question
Old Jul 19, 2010 | 09:48 PM
KingRanchFreak's Avatar
what is the most possible backspacing to run with the rough country 6" lift?
Old Jul 20, 2010 | 11:10 PM
anybody. anybody?
Old Jul 21, 2010 | 12:07 AM
IDNC76's Avatar
whats the width of the tires you want to run ?
Most i would run is 5.71 bs. you dont want the rims to be too tucked in or it wont look right.
personally i would run anywhere inbetween 4.5"-5.25" bs.
Old Jul 21, 2010 | 01:07 AM
MUDDUCK7's Avatar
I believe it's 4.5 if I recall right. To be 100% positive just call Rough Country themselves and they will tell you.
Old Jul 21, 2010 | 09:04 AM
Shooter-MMA's Avatar
Howdy neighbor.
This is what their instructions say:
This suspension system was developed using a 35X12.50/17, tire with factory wheels. The lift was designed to lift the
front 6” and the rear 5-5 1/2” to level the vehicle. Due to manufacturing, dimension variances, and inflation all tire and
wheel combinations should be tested prior to installation on all oversized / wider then stock tires We recommend a
wheel not exceeding 8" in width be used with a minimum backspacing of 4.5" to a maximum of 5".
Old Jul 21, 2010 | 04:35 PM
6"_isnt_enough's Avatar
I believe mine are 5" u can look at my pics in my album to get an idea
Old Jul 21, 2010 | 06:04 PM
Originally Posted by Shooter-MMA
Howdy neighbor.
Howdy to you too, neighbor! So what this is saying is that you could technically run your rough country 6" lift with stock rims. However, I do not plan on using my stock 20" wheels. But what I understand from this is that i would be ok to use a 8.5" wide 18" wheel with 5.71 inches of backspacing. Those are the specs of the wheels im planning on ordering. And 35" Toyo MTs. The thing that i was worried about is that maybe the rim or the tire sidewall would contact the knuckle.
Old Jul 24, 2010 | 01:36 AM
gmhater's Avatar
I have the rough country lift and i had to get 1in wheel spacers so my stock wheels and 35s would work
Old Jul 30, 2010 | 02:19 AM
midwestoffroad's Avatar
4.5-5" is what RCX recommends (for a 18" wheel)
