Sponsored by: CARiD
Couple of Questions While Installing 6" RCD Lift
Old Jul 18, 2010 | 12:58 AM
NORTH50's Avatar
I have an 06 F150 with 152k miles and will be adding an RCD 6" lift to it. My question is what are all the wear items in the front end I should look at replacing while I have the front apart. I figured lower ball joints, tie rod ends, and upper control arms. Am I missing anything? Also the RCD kit comes with Billstien 5100's that are adjustable for 4.5 or 6" can I put my AS 2.5 leveling kit on top of these?Also I've looked into the fabtech steering stabilizers, would these be needed or worth doing? Thanks
Old Jul 18, 2010 | 11:45 AM
03rappy1987's Avatar
Sounds like you know what your doing! Stabilizers I hear are great, I just stacked my spacers ha ha so you should be good when it comes to adding the leveling kit. Ball joints and UCA are all that I know that would need work.
Old Jul 18, 2010 | 07:31 PM
NORTH50's Avatar
Thanks for the reply, anyone else with any thoughts on this before I place my order from rockauto.com.
Old Jul 18, 2010 | 07:34 PM
sampson01's Avatar
i got the steering stabilizers myself and they rock.... completely got rid of my shimmy and def look BADA$$
Old Jul 18, 2010 | 09:37 PM
wandell's Avatar
You are on the right track. I think that the Fabtech steering stabilizers would be a good idea also.
Old Jul 18, 2010 | 10:06 PM
NORTH50's Avatar
Thanks guys, I've found the Fabtech FTS8009 steering stabilizer for $155 is that a decent deal? Will I be able to use the bracket that comes with these or are they made to mount on a fabtech lift? Thanks again for the help.
Old Jul 19, 2010 | 09:24 AM
sampson01's Avatar
Sounds like a good price I believe I got mine for 171 shipped
Old Jul 19, 2010 | 02:05 PM
6"_isnt_enough's Avatar
Are steering stabilizers really necessary with rack and pinion set up? do they make a noticeable difference?
Old Jul 19, 2010 | 06:13 PM
I believe they work on any 6" lift
From what I know, it takes all the shimmy out of your steering wheel from running the 35s+
