Sponsored by: CARiD
lifted but not level
Old Jul 13, 2010 | 12:49 AM
bulldawgfan141's Avatar
So I've had my 6 inch BDS lift for a couple months now and it rides fine but the front of the truck sits about 3/4" to 1" lower then the back and its pissing me off. The place where I got it installed said there is nothing I can do about it but I just wanted to check and see if anyone had any ideas.
Old Jul 13, 2010 | 01:03 AM
wingman4's Avatar
daystar 1.5 level kit would probably fix it. or crank your coilovers if you got those
Old Jul 13, 2010 | 11:24 AM
fx4 for life 79's Avatar
what did they lift the rear with? cause i know one of my friends had his bds lift with a block and aal setup so maybe you could take the aal out if you have one
Old Jul 13, 2010 | 12:10 PM
gouldje's Avatar
throw your old lady it the back
Old Jul 13, 2010 | 11:56 PM
yea its a block and aal but I want to try and lift up the front instead of lower the back because I don't want to lose hieght
Old Jul 14, 2010 | 01:38 AM
IDNC76's Avatar
My BDS lift sits the same way, it was mayb 1-2" higher in the rear. with the block + AAL
I put a 1.5" Leveling kit on and now it sits pretty level , a tad higher in the front if anything.
Old Jul 15, 2010 | 12:19 AM
[QUOTE=IDNC76;4277176]My BDS lift sits the same way, it was mayb 1-2" higher in the rear. with the block + AAL
What leveling kit did you use. and is that the 8 inch bds lift with 37's?
Old Jul 15, 2010 | 11:06 AM
i believe he has the 6" with the 1.5" spacer and a 3" bodylift
