can you add a leveling kit to a stage 1 procomp lift
im looking to raise my truck up an extra 2 inches front and rear on top of the suspension lift. is it ok to put a leveling kit on the front or do you have to use coilovers
Everyone will have a different opinion on this, but I have the same set-up you are wanting to go w/ eexcept mine is a 2.5" leveling spacer. I would recommend getting the Bilstein's if the Coilovers aren't in your budget right now. The stacked spacer's ride really rough. It's actually stiffer than the rear of my truck w/ an AAL. To answer your question, yes you can do it, but stacking spacers isn't the saftest way to do it if you off road a lot. It's kind of like stacking rear blocks; it can be done, but there are better ways to acheive the lift. My truck doesn't see any offroading so I haven't been in a big rush to replace them.
