Info on my truck and lift
i have an 04 f150 with a pro comp stage one 6 inch lift, with 35/12.50s right now. im just not liking the stance. i ordered a 3 inch PA body lift yesterday and going to switch up the wheel and tires. thinking about going to a 37 or 38/14.50 inch toyos or mickey thompsons mtzs and 18 inch rims. the question i have. is to get an additional 2 more inches can i install coilovers on the front and crank them 2 inches and install a 2 inch add a leaf in the rear. will the leaf spring still install fine even with the procomp blocks. if anyone has this set up can you post pics. just wondering if i could do that with the body lift and the suspension lift. if everything will work it would make a total of 11" of lift along with an extra couple of inches with bigger tire. any help would be appreciated.
I'm sort of in the same boat. I have a PA bl lift and will be adding an RCD 6" lift with the billstein 5100's do I leave the AS level in? And look forward to the answers to the above question as well. Also when going to 37's if you regear to 4.56 or 4.88 will the truck still run 80 down the interstate. Sorry for sort of jacking your thread but this along the same lines. Are you going to install the body lift yourself? Why would you go to an 18" wheel?
This is what 11inches looks like. 6inch Suspension, 3inch Body Lift, 2inch Leveling Kit
Yes you can get coilovers and have them cranked up to 2inches. You should be able to use a 2inch aal for the rear and shouldnt have any problems
oh so you can use a leveling kit on the front. i didnt know you could do that. someone told me you couldnt use it with the procomp stage one lift. if thats the case i have my old leveling kit that i could put back on and just get the add a leaf. that would save me some dough right there. haha. so that with the PA body lift will look pretty close to yours. after i get me some bigger tires. im pumped now. your truck is awesome man. cant wait to see how mine turns out. im going to have to put some 2 inch spacers on my truck though to fit a bigger tire. my rims sit in too close to my springs. it will prolly rub if i dont.
So why would anyone go with 4.56, is it just for mpg? 17" of lift makes 37's look small your truck is a beast.
you have a few options with the front and the rear
Front :
1) if you want to get rid of the spacer you can buy a set of coilovers and crank them up. ( most expensive, but best route )
2) you can keep the pro-comp spacer and get the adjustable bilsteins , set them to the 2" setting.
3) bilstein makes a replacement 6" strut you can get them and also a 1.5"-2" leveling kit. ( best alternative with out spending alot of money)
Rear :
Personally i would get rid of the stacked blocks.
1) get a new leaf spring set-up ( most expensive but best route)
2) get a 5/6" block and 2" AAL
once you do all that i would go with 4.88's for gears and a set of 38's.
I have the setup your looking for. 10.5" of lift and 38's.
6" BDS lift with replacement struts w/ a 1.5" leveling kit and a 5.5" block with a 1.5" AAL in the rear and a 3" Body lift with 38/13.5 toyo M/ts.
My street is on a slant , but the truck sits pretty level , a tad higher in the front if anything.
Front :
Rear :
Idk im already getting bored with it so i may just finish it and sell it or just have it for whenever i feel like driving it and then build another truck.
thanks man. i will prolly just order the 6" replacement shocks and just add my old leveling kit to it. i looked up the bilstein shocks, there not too bad. about 300 for the pair.
Front :
Rear :
Front :
Rear :
if i go with the replacement 6" shocks. that replaces the procomp spacer correct? and then you just add whatever inch leveling kit you want.
